Views and view groups (explained)
If you have a large or complex hierarchy of view groups, the search function does not only ease the navigation. It also adds the ability to search across the existing structure. How well this goes, depends on your organization having worked out a well considered and consistent naming convention for views and cameras.
CameraSearch_ExpandedGroups
The example below shows the benefit of searching instead of navigating through a complex hierarchy when you need to get an overview of related views:
CameraSearch_SearchFiltering
You can search for views that contain specific cameras or view item types. For example, if you want to see all views that contain PTZ cameras, cameras from a certain manufacturer or views that contain these view item types:
Finally, you can search for keywords.
© 2018 Milestone Systems A/S
