Mask areas in a recording during export
When you export video, you can add privacy masks to cover selected areas. When someone watches the video, the areas with privacy masks appear as solid blocks.
Note: The privacy masks that you add here only apply to the current export and for the selected video. The export may already include video with privacy masks configured by your system administrator. For more information, see Privacy masks (explained).
To mask one or more areas in the recording, follow this step:
Note: The preview image contains an invisible grid. When you add a privacy mask, what you’re actually doing is selecting cells in the grid. If the area you select includes any portion of a cell, the system masks the entire cell. The result can be that the system masks slightly more of the image than you intended.
Tip: You can temporarily switch between mask and unmask modes by pressing the CRTL button while you make a selection. For example, if you added a mask but the selected area is larger than you want, you can press the CTRL button and then unmask part of the selection without having to click the subtract_selection_light_16x16 button.
To unmask part of a privacy mask, follow this step:
To remove all privacy masks, follow this step:
© 2018 Milestone Systems A/S
