You can select or search for existing views or cameras in the Select view list. However, to add or edit views, for example renaming the view or changing a camera, you need to switch to advanced mode.
Steps:
If the button is not available, you cannot switch to advanced mode. In that case, please contact your system administrator.
For more information, see Modes in XProtect Smart Client (explained).
© 2018 Milestone Systems A/S
