Change the geographic background on smart map
By default, the basic world map geographic background displays when you add a smart map to a view. After you add a smart map, you can select a different geographic background. Everyone who uses the smart map sees the new background the next time they display the view.
Requirements: The Bing Maps and Google Maps geographic backgrounds are available only if your system administrator has set them up.
Steps:
  1. Select the view that contains the smart map.
  2. In the toolbar, click layers Show or hide layers and custom overlays.
  3. Under Geographic backgrounds, select the background and the type of detail that you want to display. For example, if you want to see topographical information, select Terrain. If you want to see roads, select Road.
© 2018 Milestone Systems A/S
