Manage default settings for smart map
After adding a smart map to a view, and you have added the overlays, cameras, and links, you can specify the default settings for the custom overlays. You can also delete custom overlays to clean up.
Steps:
  1. Click Setup.
  2. Click Config_map Manage default settings.
  3. Do any of the following:
  4. Click Save.
For more information, see Smart map default settings (explained).
© 2018 Milestone Systems A/S
