Assign a shortcut number to a view
In setup mode, you can assign shortcut numbers to views to let users select views using standard keyboard shortcuts.
- In setup mode, in the Views pane, select the view you want to assign a shortcut to.
- In the Shortcut field, specify a shortcut number, and then press ENTER. The shortcut number appears in parentheses in front of the view's name.
- Repeat as necessary for other views.
© 2018 Milestone Systems A/S
