Important: Views can only be copied within the same session; you cannot copy views from one XProtect Smart Client to another.
If you have a view and you want to reuse it, you can copy it. You can also copy a group of views or a private view to a shared view.
Or press CTRL+C.
Or press CTRL+V.
Tip: Alternatively, you can select and drag the view to another folder.
Or right-click and select Rename.
Or right-click and select Delete.
Important: Deleting a group will delete all views and any subgroups within the group as well.
© 2018 Milestone Systems A/S
