Get help
The help system is context-sensitive, which means it automatically displays a help topic relevant to the area you are working with.
When you print a help topic, the topic is printed as you see it on your screen. If a topic contains expanding drop-down links, click each required drop-down link to display the text in order for it to be included in your printout.
© 2018 Milestone Systems A/S
