Show or hide layers on smart map
You can show or hide layers on your smart map, including the geographical background. For example, this is useful when you want to focus on a particular element, or just simplify the content that the smart map is displaying.
Steps:
  1. On the toolbar, click layers Show or hide layers and custom overlays.
  2. To show or hide system elements and custom overlays, select or clear the check boxes.
  3. To hide the geographic background, select None.
    Note: Selecting None hides the geographic background, but the geo-references still apply to the smart map. For example, if you add a new shapefile that contains spatial reference, the system will still use the spatial reference to place the file on the map.
© 2018 Milestone Systems A/S
