Select or change the icon for camera
You can choose a camera icon that matches the type of camera you are using.
  1. Select the view that contains the smart map you want to work with.
  2. Click Setup, and then double-click the camera icon on the map.
    smartmap_camera_change_icon
  3. Click Pick icon, and then select the icon for the camera.
  4. Click Setup again to save the change.
© 2018 Milestone Systems A/S
