Show or hide information about cameras
You can show or hide information about cameras on a smart map. This is useful, for example, when you want to increase or reduce the amount of content on your map.
- Select the view that contains the smart map you want to work with.
- Click Show or hide layers and custom overlays.
- Select or clear the check boxes for the information to show or hide.
© 2018 Milestone Systems A/S
