Change cameras in views
You can temporarily change the cameras that are displayed in a view. However, this feature is for provisionally switching cameras; it does not permanently change the view. To restore your original view, click the reload view button on the workspace toolbar: . If you want to permanently change the content of a view, you must be in setup mode.
You cannot change cameras if the view contains a hotspot, carousel, or Matrix content. If used from the Cameras pane, the feature works with Smart Wall positions as well.
This method can also be used for dragging cameras onto Smart Wall positions, but only if used on the Live tab.
  1. Select the relevant position in the view.
  2. In the Cameras pane, drag the relevant camera into the position in the view.
    Alternatively, on the camera toolbar, click More > Camera, and then select the relevant server and camera.
    The original camera is listed at the top of the right-click sub-menu and named (default). This lets you quickly switch back to your original view.
In the Cameras pane, the list of cameras is grouped by server . If a server is listed with a red icon, it is unavailable, in which case you will not be able to select cameras from that server.
Tip: If camera shortcut numbers have been defined, you can use keyboard shortcuts to switch between cameras. If a camera shortcut number has been assigned, it appears in parentheses in front of the camera name.
Swap cameras
© 2018 Milestone Systems A/S
