Add location to smart map
To keep track of the places that are of interest to you, you can add locations that allow you to quickly navigate to those places on the smart map.
Steps:
  1. Select the view that contains the smart map, and click Setup.
  2. If needed, pan and zoom in to the point on the smart map where you want to add the location.
  3. In the toolbar, click Location_add Add a location, and then click the point on the smart map.
  4. Give the location a name, and then add the following optional details:
© 2018 Milestone Systems A/S
