Display text on more than one Smart Wall
When you have added text to a view item, you can send the text to more than one Smart Wall.
Steps:
  1. Add text to your view item as described in Add text to view item or Smart Wall.
  2. After you save, click More > Send to Smart Wall.
  3. Select the Smart Wall setup and then the monitor.
  4. Select the position on the monitor.
  5. Repeat these steps for each Smart Wall.
© 2018 Milestone Systems A/S
