Display image or snapshot on Smart Wall
You can display an image from your computer, for example of a suspect, on your Smart Wall, or take a snapshot of an incident and then display it on your Smart Wall.
You can also add images to views and then send it to more than one Smart Wall. For more information, see Add image to view or Smart Wall.
  1. On the Live or Playback tab, roll the mouse over the view item that is showing the footage.
  2. To display a snapshot:
    1. On the view item toolbar, click the Create Snapshot sc_create_snapshot icon . The system saves the image to the location specified in Application options.
    2. Drag the snapshot from the folder to a tile in the Smart Wall overview.
    3. In the Smart Wall view item, click view_options_dropdown_19x8_Dark_SCREENSHOT and select a display option, for example Primary Display. For more information, see View live or recorded content in XProtect Smart Wall.
  3. To display an image located on your computer:
    1. In the folder on your computer where the image is located, find the image.
    2. Drag the image from the folder to a tile in the Smart Wall overview.
When you drag an image to the Smart Wall overview, the system automatically embeds the image so that the image is available from anywhere.
© 2018 Milestone Systems A/S
