When you have added an HTML page to a view or Smart Wall, you can set the properties, for example the size of text displayed on the HTML page.
Requirements: You have added the HTML page to your view or Smart Wall. For more information, see Add HTML page to view or Smart Wall.
Steps:
As a rule, with a high scaling value such as 1280×1024, text on the HTML page will appear relatively small. With a low scaling value, such as 320×200, text on the HTML page will appear relatively large.
If selected, a client script required for navigating and controlling a number of features inside the XProtect Smart Client will be added to the HTML page. For HTML pages which are not going to be used for such purposes, the client script cannot be used, and may even cause the HTML page to malfunction.
If you do not want the navigation bar, you can hide it by selecting Hide toolbar.
© 2018 Milestone Systems A/S
