Add Smart Wall overview to view
After your system administrator has set up your Smart Wall in the Management Client, you can add it to one or more views.
Steps:
  1. Click Setup to enter setup mode.
  2. Select the view where you want to add the Smart Wall.
    Wide layouts are especially suitable for displaying Smart Wall content. The bottom of the 1+1+2 view provides a wide position ideal for displaying Smart Wall content. The 1×3 view can graphically represent three different Smart Wall setups at the same time.
  3. In the System Overview pane, drag the Smart Wall element to the relevant view item. The view item now contains a graphical representation of the Smart Wall.
  4. Click Setup again to exit setup mode.
  5. If your organization has more than one Smart Wall, select the relevant Smart Wall.
  6. If the Smart Wall has more than one preset, select the relevant preset in the Preset list. Presets contain predefined settings that determine which cameras are displayed, and how content is structured on each monitor on the video wall.
After selecting a Smart Wall and a preset, other users can select a different Smart Wall, preset, or both.
© 2018 Milestone Systems A/S
