As an alternative to exporting video evidence, you can take a quick snapshot of an image if you want to save or share a still image. You can take a snapshot from the Live, Playback or Sequence Explorer tab, or from a carousel, hotspot or the camera navigator.
You can view your snapshot, by browsing to the snapshot file location. Snapshot files are saved in the default file location specified in Application options.
If the image contains a privacy mask, this privacy mask is also applied to the snapshot image.
© 2018 Milestone Systems A/S
