In the Properties pane, you can specify these settings for the camera navigator.
Name |
Description |
Home map and camera |
Displays the map and default camera that your camera navigator is based on. You can change these settings, by clicking the button to open the Select Home Map and Camera window. |
Maximum camera indicators |
Select the maximum number of cameras that you want to include in your main view. Each camera is shown with a camera icon . You can display an unlimited number of cameras. |
Camera indicator orientation |
Select Relative to selected camera if you want to display the location and orientation of the cameras as seen from the camera's perspective The selected camera is always the centered one. |
Maximum preview cameras |
Select the maximum number of cameras that you want to display in your preview pane. Only the cameras that are visible on the screen will use your system's resources. The maximum number of cameras that you can display is 20. Note that the more cameras that you preview, the more of your system resources they will take up.
© 2018 Milestone Systems A/S
