Edit PTZ presets
You can make changes to existing PTZ presets, such as renaming or changing the preset position:
- In the view, select the PTZ camera with the PTZ preset you want to modify.
- On the camera toolbar, click the PTZ icon
to open the PTZ menu. - Click Manage PTZ presets and in the dialog box, select the PTZ preset.
- To edit the name of the preset, ensure the name of the PTZ preset is highlighted. Click the text and overwrite the existing name.
- If the camera is not in the correct position, use the PTZ buttons to navigate to the required position and then click Update preset to save.
- Use the up or down arrows to arrange the PTZ presets on the list.
- Click Close.
© 2018 Milestone Systems A/S
