Camera navigators let you set up a complete overview of an area by adding all cameras that cover the area in a single view. For example, this is useful if you want to be able to follow someone around a building. As the person moves, you can switch to the next camera. For more information, see Camera navigator (explained).
Steps:
Tip: To get the most out of the camera navigator and to be able to see the camera views in the pane on the right, select a 1 x 1 view.
© 2018 Milestone Systems A/S
