Send content from view to Smart Wall
You can send content from a view item to a Smart Wall overview. The steps required depend on whether your current view contains your Smart Wall overview.
  1. If your current view does not contain your Smart Wall overview:
    1. On the view item toolbar, click More > Send to Smart Wall.
    2. Select the Smart Wall.
    3. Select the monitor.
    4. Select the position on the monitor.
    Send to Smart Wall
  2. If your view contains your Smart Wall overview, drag a view item to a tile on your Smart Wall overview.
The way the view item is added depends on how your system administrator set up the element insertion method for the monitor. The content from the view item either replaces the content that the tile displayed, or pushes it to the next tile in the Smart Wall overview. For example, if you drag content to tile 1, the content of tile one is moved to tile 2, and so on.
© 2018 Milestone Systems A/S
