Search using the Recording Search pane
  1. On the Playback tab, in the Recording Search pane, select either Sequences or Bookmarks.
  2. For bookmarks, select the search criteria you are interested in, for example, time, your bookmarks only, or content from the bookmark's Bookmark ID, Headline and Description fields.
  3. Select whether you want the search to include only the selected camera or all cameras in the view.
  4. Click Search. This will retrieve a list of results. The sequence closest to the time you have selected for the view appears in the middle of the list. Sequences or bookmarks from before the time you have selected appear above, and ones from after, below. Each sequence is listed with camera information, date, and time. Selecting a sequence in the list moves all video in the view to the time of the selected sequence.
  5. To display more details about each sequence or bookmark in the list, select Show details. For sequences, this displays the date and time of the first image in the sequence (green flag), the last image (checkered flag), and the motion detection, event, that triggered the recording (yellow flag). For bookmarks, Show details, displays additional information, consisting of an image from the bookmark time as well as a detailed description (if one is available).
  6. To quickly preview the video when you place your mouse over the bookmark or sequence in the list, select Auto-preview.
  7. When you have selected a sequence or bookmark in the list, you can generate a printed report or export it . For a bookmark (depending on your user rights), you can also edit or delete it. For more information, see Add and edit bookmarks, Print evidence and Exporting.
© 2018 Milestone Systems A/S
