Name |
Description |
Headline |
The headline of the evidence lock. |
Description |
A description of the evidence lock. |
Evidence lock interval start |
Adjust the start date and time for the video sequences you want to protect. |
Evidence lock interval end |
Adjust the end date and time for the video sequences you want to protect. |
Keep evidence lock for |
Specify for how long you want to keep the evidence protected. Depending on you user rights, you can have the following options: hour(s), day(s), week(s), month(s), year(s), indefinite or user-defined. If you select User-defined, click the calendar button to select a date and then adjust the time manually. When done, the date and time for when the evidence lock expires is shown. |
Select camera |
Click to select more cameras to include in the evidence lock. |
Remove/Remove All |
Click to remove one selected camera or all cameras from the evidence lock. |
© 2018 Milestone Systems A/S
