Search for bookmarks
The bookmark feature is only available when connecting to selected surveillance systems; see Surveillance system differences. Depending on your user rights, access to viewing bookmarks from some cameras may be restricted. Note that you may be able to view bookmarks even though you may not be able to add them, and vice versa.
  1. Select Bookmarks in the menu.
  2. Use the search field to search for bookmark headlines or descriptions. Matching results are shown instantly in the thumbnail overview.
  3. Select My bookmarks only if you only want to see bookmarks created by you. When you place your mouse over a thumbnail, details about the bookmark are displayed in a pop-up window.
To the right of the preview you can see details about the selected bookmark. Depending on your user rights, you may be able to edit, delete, print, or export the bookmark:
© 2018 Milestone Systems A/S
