Define search
- On the Sequence Explorer tab, select Sequence Search.
- In the Select camera... menu, find the camera that you want to view sequences for. You can add up to 100 cameras in a sequence search:
- Use the search field to search for a camera name or description, or
- Navigate to the camera in the list
- Click the camera to add it to the view.
© 2018 Milestone Systems A/S
