Adjust time
You can set the time that you want Smart Search to search from. The preview image is shown from the selected time.
You can also define a period to search within. The period is always based on the start time that you have selected. To select a start time, you have two options:
- Drag the timeline below the preview grid left or right to set the start time. Available recordings are indicated with colors. You can also use the arrows to go to previous or next frame.
- Click the current time to access a calendar where you can specify a date and time. Click Go To to set this time as start time.
© 2018 Milestone Systems A/S
