Motion threshold (explained)
The motion threshold allows you to define the smart search sensitivity.
The higher the threshold you select, the more motion you need in the selected areas before the motion is detected by Smart Search.
The lower the threshold you select, the less motion you need in the selected areas before the motion is detected by Smart Search.
A low threshold does not necessarily give more results. A high threshold does not necessarily give less results.
© 2018 Milestone Systems A/S
