View alarm reports
Alarm reports are available only if you are using XProtect Corporate, XProtect Expert, XProtect Professional+, or XProtect Express+.
You can filter the interval of the report, so it displays alarms over a period of 24 hours, 7 days, 30 days, 6 months, or a year.
Select the categories, states, priorities, reasons for closing, sites, or response times to display in each of the two graphs so you can compare these side by side. The graphs display the number of alarms on the vertical axis and the time frame on the horizontal axis.
© 2018 Milestone Systems A/S
