Joystick settings
Even though joystick control is supported for a large number of PTZ cameras, not all PTZ cameras may be joystick-controlled.
When a new joystick is detected by the XProtect Smart Client, a default pan-tilt-zoom (PTZ) configuration for the joystick is added automatically. However, the Joystick settings let you customize the setup for all your XProtect Smart Client joysticks.
Name
Description
Select joystick
Select from the list of available joysticks.
Axis setup: Name
There are three axes:
  • X-axis (horizontal)
  • Y-axis (vertical)
  • Z-axis (the depth or zoom level).
Axis setup: Invert
Select to change the default direction the camera moves in when you move the joystick. For example, select to move a PTZ camera to the left when you move the joystick to the right and move down when you move the joystick towards you.
Axis setup: Absolute
Select to use a fixed rather than a relative positioning scheme (moving the joystick moves the joystick-controlled object based on the object's current position).
Axis setup: Action
Select the function for an axis: Camera PTZ Pan, Camera PTZ Tilt, Camera PTZ Zoom, or No action.
Axis setup: Preview
Test the effect of your selections. When you have selected a function for the axis you want to test, move the joystick along the required axis to view the effect, indicated by a movement of the blue bar.
Dead zone setup: Pan/Tilt
Specify the dead zone for the joystick's pan and tilt functions. The further you drag the slider to the right, the larger the dead zone becomes, and the more you will have to move the joystick handle before information is sent to the camera. Dragging the slider to the far left disables the dead zone (only recommended for high-precision joysticks). Use the Axis setup preview to test the effect of your dead zone settings.
Dead zone setup: Zoom
Specify dead zone for the joystick's zoom function. The further you drag the slider to the right, the larger the dead zone becomes, and the more you will have to move the joystick handle before information is sent to the camera. Dragging the slider to the far left disables the dead zone (only recommended for high-precision joysticks). Use the Axis setup preview to test the effect of your dead zone settings.
Button setup: Name
The name of the button.
Button setup: Action
Select one of the available actions for the required joystick button.
Button setup: Parameter
If relevant, specify a parameter for the command or action. For example, if you want to specify the window and view position for the Copy the selected camera view item parameter, enter 2;1 to have the camera copied to the floating window (window 2), in the first view position (view position 1).
Button setup: Preview
Verify that you are configuring the right button, press the corresponding button on the joystick. The relevant button will display in blue in the Preview column.
© 2018 Milestone Systems A/S
