Change OpenStreetMap tile server
You can specify a different tile server for OpenStreetMap than the standard server specified in the configuration for your type of user profile. For example, if your VMS is not connected to the Internet, you can use a local server. Or you can use a commercial server.
Requirements: If the tile server specified in the configuration has been locked for editing, the field is grayed out in XProtect Smart Client, and you cannot change the server. Please contact your system administrator to help you enable the feature on the Smart Client profile in Management Client.
Steps:
  1. In the upper right corner, click sc_application_dropdown_arrow and then O9333 Settings to open the Settings dialog.
    sc_2016R3_OptionsDialog_SmartMap
  2. In the left section, click Smart map.
  3. In the Alternative OpenStreetMap tile server field, enter the server address. If the field is grayed out, it has been locked in the configuration.
    -OR-
    To use the server specified in the configuration, select the Follow Server check box.
  4. Click OK. The geographic background changes.
For more information about changing the tile server, see Changing the OpenStreetMap tile server.
© 2018 Milestone Systems A/S
