Additional data
If you have additional data under Timelines enabled for the Smart Client profile and additional sources are available, you will be able to see an additional layer in the timeline that designates the defined data. This allows you to view additional data that is added by other sources.
Timeline_AdditionalData
The color and the name of the additional data are defined by the source. You can see these in the legend.
Timeline_Legend
© 2018 Milestone Systems A/S
