Go to another smart map location
You can quickly jump to locations added by yourself or others in XProtect Smart Client instead of panning manually to the location on the smart map. The list of locations displays the last location you selected.
Steps:
  1. Select the view that contains the smart map.
  2. In the upper left corner of the view, open the Select a location list.
    LocationList
  3. Select the location to go to that location on the smart map.
© 2018 Milestone Systems A/S
