Preview videos from several cameras
You can preview video from several cameras on your smart map at the same time. If you want to investigate and play back the video, you can open the cameras in a new floating window. In doing so, the smart map will stay in the background in the position where you left it.
Steps:
- Navigate to the place on the smart map, where the cameras are located.
- To view video from more than one cameras in a preview window, do one of the following:
- Press and hold the CTRL key while you select the cameras, and then right-click a camera icon and select Live preview.
- Click
Select multiple cameras, then click and drag on the smart map to select the cameras. After you select the cameras, press ENTER on your keyboard. - Double-click a cluster of cameras. You can preview up to 25 cameras in a group. If one or more cameras are selected in the group, the preview window displays video only from the selected cameras.
- To play back and investigate the video in more detail, do one of the following:
- In the Preview window, click the Independent Playback button. The controls of independent playback becomes available.
- When you have selected the cameras, right-click and select Send camera > New Floating Window.
If you chose the cluster option: The icon for the group of cameras indicates whether only some of the cameras in the group are selected, for example
© 2018 Milestone Systems A/S
