Add hotspot to view or Smart Wall
When clicking a view item or tile with a camera in a Smart Wall, the video feed from the camera is displayed in a high resolution in the hotspot view item.
Steps:
- Click Setup to enter setup mode.
- In the System Overview pane, click and drag the Hotspot item to the required position in the view. The position displays a hotspot icon:
. - Click Setup again to exit the setup mode.
- (optional) To set the properties for the hotspot, in setup mode, go to the Properties pane.
- To send the hotspot to your Smart Wall, see Display hotspot on Smart Wall.
To save bandwidth, you can specify a low image quality for the other positions in your view and a high quality for the hotspot.
© 2018 Milestone Systems A/S
