Add Matrix content to a view
  1. In setup mode, in the System Overview pane, drag the Matrix item to the position in the view where you want to add Matrix content. A blue border appears indicating that the position in the view has Matrix content.
  2. When you select a Matrix position, you can specify its properties in the Properties pane.
    When viewing live or recorded video, you can double-click a Matrix position (or any other camera position in a view) to maximize it. When maximized, video from cameras in the Matrix position is displayed in full quality by default, regardless of your image quality selection. If you want to make sure that the selected image quality also applies when maximized, select Keep when maximized.
  3. Repeat for each Matrix position you want to add.
© 2018 Milestone Systems A/S
