Add or edit bookmarks
- Select the required camera in the view.
- Click the bookmark icon
. If you have specified that you can add details in the Settings window, the Bookmark window appears where you can add a detailed description of the incident. The length of a bookmark clip is determined on the surveillance system server, but you can change this by dragging the timeline indicators. Tip: Do not worry if it takes a while to enter the details for your bookmark; the XProtect Smart Client remembers your bookmarks until you click Save (unless it takes several days to create the bookmark and the video no longer exists on the surveillance system).
- Click OK.
© 2018 Milestone Systems A/S
