Evidence locks (explained)
With the evidence lock functionality, you can protect video sequences from being deleted, for example while an investigation or trial is ongoing. This protection also covers audio and other data from devices related to the selected cameras.
Once an evidence lock is in place, the system protects the data from being deleted. This means that neither you nor other XProtect Smart Client users can delete the data until a user with sufficient user rights unlocks the evidence. With an evidence lock, the data is also protected from automatic deletion that would otherwise take place based on the system’s default retention time.
Depending on your user rights defined by your system administrator, you may or may not be able to create, view, edit and delete evidence locks.
© 2018 Milestone Systems A/S
