Create evidence locks
  1. Select the Playback tab.
  2. In the timeline, click the Time Selection Mode or the Set Start/End Time button.
  3. Select the start and end time for the video sequences you want to protect from deletion.
  4. Select one or more cameras that have video sequences and data from related devices that you want to protect.
  5. To the right of the timeline, click Evidence Lock and select Create.
  6. In the Create Evidence lock window, give the evidence lock a headline and optionally add a description.
  7. Click Select camera to add more cameras to the evidence lock.
  8. Click Remove or Remove All to remove cameras from the evidence lock.
  9. You can adjust the time interval and define for how long you want to keep the evidence protected. See Evidence lock settings for more information.
  10. Click Create.
  11. A window shows if your evidence lock was created successfully. Click Details to see what went well and what did not. See Evidence lock status messages for more information.
© 2018 Milestone Systems A/S
