Logging in (troubleshooting)
If a problem or other issue occurs during login to XProtect Smart Client, you will see one of the following error messages:
Your user rights do not allow you to log in at this point in time. User rights may vary depending on time of day, day of week, etc...
You do not have access to any part of the application. Contact the system administrator.
Authorization failed: You cannot authorize yourself.
Authorization failed: You do not have permission to authorize.
Failed to connect. Check the server address.
Failed to connect. Check the user name and password.
Failed to connect. Maximum number of clients are already connected.
New Client available. Upgrade is recommended/required. The new version can be downloaded from.
Application is not able to start, because two (or more) cameras are using the same name or ID...
Some messages will appear in an orange ribbon above your views:
You no longer have permission to do this
Due to system settings, your XProtect Smart Client session will expire within the next [...]
No user activity detected recently, your XProtect Smart Client session will expire within the next [...]
© 2018 Milestone Systems A/S
