Create view
To view or play back video in XProtect Smart Client, first you must create a view, where you add the cameras you need.
Requirements: Before creating the view, you need a group that you can add the view to. For more information, see Create a view group.
Steps:
- In the right corner, click Setup to enter setup mode.
- In the Views pane, select the group you want to add the view to.
- Click
to create a new view. - Select a layout. The layouts are grouped according to their aspect ratio (height/width relationship), and according to whether they are optimized for regular content or content in portrait mode (where the height is greater than the width).
- Enter a name for the view by overwriting the default New View name.
- Click Setup again to exit the setup mode.
Views can be private or shared.
© 2018 Milestone Systems A/S
