Manage default settings for smart map
After adding a smart map to a view, and you have added the overlays, cameras, and links, you can specify the default settings for the custom overlays. You can also delete custom overlays to clean up.
Steps:
- Click Setup.
- Click
Manage default settings. - Do any of the following:
- To show or hide an overlay, select or clear the check box
- To rearrange the order, use the drag handle in front of the overlay to drag it to a new position in the list. Layers are ordered from top to bottom in the list.
- To delete an overlay, hover the pointer over the overlay, and then click Delete.
- Click Save.
For more information, see Smart map default settings (explained).
© 2018 Milestone Systems A/S
