Add an overlay button to a view
You can activate speakers, events, output, and more through overlay buttons which appear when you move your mouse over individual camera positions in views on the Live tab.
You can add as many buttons as needed.
- In setup mode, in the Overlay Buttons pane, select and drag the action onto the camera position.
- When you release the mouse, the overlay button appears. To resize the button, drag the handles that appear.
- If you want to change the text of the overlay button, double-click the text, overwrite it, and then click the check mark button
to save. To undo, click the cancel button
. When you save, the text scales to the largest possible size on the button.
© 2018 Milestone Systems A/S
