Add cameras to smart map
If the GPS coordinates of the camera has been specified in Management Client by your system administrator, automatically it will be positioned on the smart map when you add it. If not, you must position it yourself in its exact geographic location.
- Select the view that contains the smart map, and then click Setup.
- To add a camera, or a group of cameras:
Tip: Before you add the camera, it's a good idea to zoom in to the location on the map. This makes it easier to accurately position the camera.
- Expand the System Overview pane, find the camera or camera group, and then drag it to the point on the smart map where you want to display it. You can drag cameras afterward to reposition them.
- On the smart map toolbar, click
Add a camera, and then select the camera.
- To save the change, click Setup to exit setup mode.
© 2018 Milestone Systems A/S
