Select or change the icon for camera
You can choose a camera icon that matches the type of camera you are using.
- Select the view that contains the smart map you want to work with.
- Click Setup, and then double-click the camera icon on the map.
- Click Pick icon, and then select the icon for the camera.
- Click Setup again to save the change.
© 2018 Milestone Systems A/S
