Display video or still image from bookmark on Smart Wall
Sending a bookmark to a Smart Wall can help you quickly distribute a single image of, for example, a person or a video sequence of an incident.
Steps:
- If you are on the Live tab, in the camera toolbar, click
to create a new bookmark. - If you are on the Playback tab, do one of the following:
- In the camera toolbar, click
to create a new bookmark. - In the Recording Search pane, select the Bookmarks check box and click Search to locate your bookmarks.
- In the search results, select your bookmark and click
to edit the bookmark.
- In the Headline field, enter a name or title for the bookmark.
- Click Display on Smart Wall, point to the Smart Wall, then the monitor, and then click the tile where you want to display the video or image.
- To send a video clip, click OK.
- To send a still image, select the Send still image only check box and click OK.
- Send the Smart Wall to a view as described in View live or recorded content in XProtect Smart Wall.
© 2018 Milestone Systems A/S
