When you minimize the camera toolbar in a view item, the toolbar remains minimized only to you in the current session. However, you can hide it permanently for a particular view item, for all users with access to the view item.
Steps:
The setting you make in setup mode is stored on the server, so that the change impacts other XProtect Smart Client operators.
© 2018 Milestone Systems A/S
