Add buildings to smart map
Instead of using images or shapefiles to illustrate buildings, you can add an outline of a building. Afterwards, you can change the dimensions, angles, and size to match the shape and position of the actual building.
Requirements:
Smart map editing has been enabled on your Smart Client profile in Management Client.
Steps:
- Click Setup to enter setup mode.
- Navigate to the place on the smart map, where you want to position the building.
- Click
and place the cursor in the relevant position on the smart map. - Click again. A rectangle is added to the smart map. If zoomed out, the zoom level automatically increases.
- If necessary, use the corner handles to adjust the shape and position of the actual building.
- Click Setup again to exit setup mode.
© 2018 Milestone Systems A/S
