Delete buildings on smart map
If a building is no longer needed, you can delete it. Next time someone logs into XProtect Smart Client or reloads, the building is gone.
Requirements:
Smart map editing has been enabled on your Smart Client profile in Management Client.
Steps:
- Open the smart map.
- Click Setup to enter setup mode.
- Do one of the following:
- Right-click the building and select Delete, or press DELETE on your keyboard.
-Or-
- Click
Manage default settings. - Scroll down to the Buildings section.
- Hover on the building you want to delete. The text Delete appears.
- Click Delete and Save. The building disappears from the smart map.
© 2018 Milestone Systems A/S
