Add or remove levels from buildings (smart map)
After adding a building to your smart map, you can add any number of levels. The first level is assigned the number 1, the next 2, and so forth. Afterwards, you can rename and change the order of levels.
Requirements:
Smart map editing has been enabled on your Smart Client profile in Management Client.
Steps:
- Navigate to the building on your smart map. If necessary, zoom in.
- Select the building. A pane appears on the right-hand side.
- Click the Setup button to enter setup mode.
- Click Add level
. - To edit the level name:
- Click the dots
and select Rename. - Enter a new name.
- To delete a level, click the dots
and select Delete. Cameras on this level stay in their geographical position, but are no longer associated with the level. - Click Setup to exit setup mode.
© 2018 Milestone Systems A/S
